Where to buy older round headlights
  • Where to buy older round headlights
    where can I find the round style headlights? I have a 1994 Max2. checked classifieds and ebay...no luck. HELP!?!?
    Any local auto parts store will have them. Just take yours in and they will match it up. I got mine at NAPA.
      great to know. Thanks!
        wait, do you have a part number for the light you bought at Napa? Just pulled the light out and it looks prety specific to the Max
          i have found them at auto parts stores and Tractor Supply. there is nothing special about them
            Some of those replacement bulbs you have to paint the back side
            to keep the light from entering the inside
              Never thought about painting the backs of the builb to keep light from leaking through into the cab. Did you use regular paint, or high temp stuff??
                just whatever
                  The Owner's Manual says that the Max II headlight bulb is a "GE 4414, 18 Watt". The Max IV and Buffalo bulb is a "Tung Sol #4439". Uncle Vin
                    when you buy those get the holigen type, i think its a different #
                      Duckworks Aviation - RV Light Upgrades
                      This is what I have in HOGWILD fits great in the rubber ring NP.I have the try NOT the spot and am using the crystal blue lite(100watt ) 4 amps draw from autozone. WHAT A BIG BIG DIFF. Oh for the guys and gals that dont know that rubber ring is just a brake light gommet. The thing I like about this set up is you dont have to change out the hole light and the bulb you can find at any parts store. Hope this may help some one out.
                        paint it red or blue transparent paint and you will have sex lights under your dash
                          If you are looking for a brighter light, look into these. I bought these for my Max (also a 94) and they fit into the headlight grommet ring with no problem. This allows you to change to a brighter or dimmer bulb if you need to and uses a very common H3 style bulb. He just came out with the led bulbs at the top of the page.....has me wondering how those would fit! Duckworks Aviation - RV Light Upgrades
                            This looks like another LED option at a lower cost. Perhaps the light experts could chime in and compare brightness of this bulb.
                            Truck-Lite 80220 LED PAR36 Sealed Beam Lamp Work Light 4411 Bulb Replacement | eBay
                            WANTED: MAX IV
                              wow those would be pretty cool, wish I had an extra 75 bucks layin around
