Is there anyone who has modified there adjusters to hold them up would like to buy ones from richards relics but its going to be awhile before i can afford them i modified the back ones with good results so far but cant do the same for front cause of floor board any one need some ideas please
max chain adjusters
I'm assuming this is a Max II with the ratcheting style adjusters? If so, you can probably take them all the way out by removing the four bolts that hold the entire assembly in the frame rails, and fix them. You may not even have to take them out. It almost sounds like you are missing the spring clips that keep the adjusters together, holding it in one place. Either that or the back of your adjusters are really worn out but I doubt that would happen on all of your adjusters. Look at this how-to guide to see if your adjusters are missing the sprung piece of metal that holds everything in place: Max chain adjuster replacement
I got the one's from Richard's several years ago. They are far superior to the ratchet style. They require little adjusting, it just takes a wrench to loosen one bolt, then I use a big screwdriver to push the adjuster into proper tension, then retighten the one bolt, and its done. Do yourself a favor and ditch the ratchet style, they are prone to gunk up or rust up quickly anyway.
I looked at the ones Richards relics sells and made my own set.Richard sorry but I thought yours where on the pricey side. They work great so kudos on your design Richard. I would suggest to anyone to replace their racheting style with these. Or do as I did and fab your own.
