I'm as new as they come to the whole 6x6 thing, but I did some work on my just purchased max II today and figured alot of syuff out about them.
Anyway, I took all the wheels off today in order to grease the fittings right behind them and realized that a couple of the axles would wiggle around slightly if I shook them. So I figured I would need some new bearings.
So, My question is:
How much money and time am I looking at spending on changing all the wheel bearings? Also, do I just change the bearings, or are there many parts that should be changed while I'm in there? The max took on some water today on my first ever ride in the pond, so I assume the spots where the axles come out of the body must be leaking, so I should replace that too?
Thanks, and remember, this is the only the 3rd day of owning this max, and mine is the only one i've ever seen, so the "obvious" to you is probably not obvious to me,
So, My question is:
