Sunk max
  • Sunk max
    I have a max II with an 18hp briggs that was sunk by a buddy. Total rear end submerged. Do these motors usually hold up well if properly cleaned out and new fluids run threw a couple times or should i get a new motor. Any issues with cleaning out tranny and new fluids in it as well. it is a 96 model with very lows hours that ran fine before.
    Get the water out asap. Pull the plugs and crank it over, then drain the oil. With fresh oil start the motor, let it run(idle) for 30 sec to 1 min. Shut it down and check the oil. If it looks foamy at all you did not get all the water out....change oil again and repeat. If the oil looks ok run it longer and recheck, but it's probably ok. You may have to pull the carb to clean it out before it will start, depends on how bad it was submerged. The fuel tank is up front and shouldn't have taken on water, otherwise you would have to drain it and change the filter/flush lines. The t-20 may not have taken on water, but it would be a good idea to change the oil, drive it a little and change it again. Look for foam, that means water. It's not the end of the world, just a minor setback. Once the water is out all should be OK. Good luck
      I sank my max II this summer to the bottom almost. First pull the plugs and hand roll it you'll see water come out if you do check your air filter thats where it got in. Dry the air filter drain oil and change the oil filter. After i drained my oil i added fresh in and hand rolled it a few times and drained it again to help get most of the water out. That seemed to do the trick...fresh oil fired it up and ran like a champ plus now I know its nice and clean inside. And buggyman1 has experience look up his videos he may of sunk an AATV before I hear.
      The feat of sinking a max is a badge of honor.
        Just as an FYI, water doesn't have to get any deeper than a few inches up the engine block on a Vanguard to fill the carb and intake/and then cylinders with water.. IF you let the engine continue to run. The fins on the flywheel's cooling fan will throw water up into the air cleaner via that rubber boot between the cowling and air filter base that normally supplies fresh/cooler air.
          2 strokes are a little easier to clean the water out of....no oil/filter to worry about or carb float bowl.
            Originally posted by thebuggyman1 View Post
            http://www.6x6world.com/forums/trail...july-11th.html
            Thats for sure, a buddy blasted his 1/5 scale R/C into a swamp. I think it was 1/2 hour before it was running again, maybe less. My neighbor sank an Outboard in SALTwater, and put it away for the winter. Cleaned it up in the spring and after setting it on fire he got it running. This is certainly luck though, it should be dried out ASAP.
            Attex Super Chief - Sold.
              It will be floating for a while yet. The ice is to thin to get it out for now. The front 2 tires are all that is out of the water. Hopefully by early next week it can be pulled to dry land and taken in for clean up. Thanks for the info
                Where are you located? Maybe a local member will pull you out with thier machine. The sooner you get it out of the water and dried out the better.
                  If you wait for the ice to thicken up it'll be frozen in good. Are you planning on cutting it out with a saw? You'll certainly need to drain the Tranny and dry it out too. Your guess is as good as mine, but mine would be that you'll get it going again, just with a good exercise in tearing the motor and tranny down. I'm with buggyman, find a local AATV owner or use a rowboat (if Ice is thin enough to break up a passage) but get it the heck out of there before ice squeezes something the wrong way, breaks a bead and it becomes a Scuba mission.
                    Ice is real bad heavy snow insulating it and the weight is causing water to pump up in weak spots making lots of holes under the snow. It is to thick for a boat and has a lot of bad holes like the one the max went in. Yeah just as soon as the ice gets thick enough to get right up to it going to cut it out and lift it up and out on ice. And no I didn't drive it out there.
                      Just a thought, but if someone has an inflatable dinghy you could use a paddle or pole to push yourself out with a heavy rope and second rope, cut the max out (leaning on the tube, don't leave it) attach heavy rope/cable and get pulled in by the smaller rope. Now winch the max in. Just a thought, but the dingy won't go through, it'll spread the load out a lot, and EVEN if it did, you'd be floating with a rope to get pulled right back in. Personally, I think this is how I'd attack it. I'd be confident only since I'm in something that floats better than an AATV, and I have assistance and a tow rope handy already. Just be sure the saw is covered so the teeth don't meet the tube
                        It is about thick enough to get an atv to it now. It is over 150 yards off shore and it is like a mine field of holes of thin ice under the snow. Should be getting pulled out first of week and start pulling motor and tranny. Have a trailer with a boom and winch to lift it up while pulling it out of hole. It is in a remote area so getting stuff to it is not easy. Should be out first of week. My only worry is if it will impact long term durabilty. Motor and tranny are coming out to get cleaned and dried so hope that does it.
                          hi i've sank my max II 2 times it
                          s still running get the water out asap take the carb apart clean it get it back to running as soon as possible i changed the oil 3 to 4 times till i get it clean u might need to put some in the cyd to coat them a good cleaning will take care of most of it robbie
                            it will be fine. as soon as you get it out you need to get right on it. get water out of the cylinders and crank case. I do oil changes, run motor, then see if oil is clear. repeat till clean. you need a winch, some extra big rope, and a truck. do they have kayaks around you? you could use one to slide out to the machine if you worried about falling through..
