MaxII chain adjusters
  • #16
    Thanks Mike.That is a good post on teflon replacement.Mine aren't completely worn out but I have the machine tore down for bearings and its a great chance to do it with the chains out of the way.
    • #17
      As an update to this thread.....I did end up using the roller style ones on this machine and they worked fine.
      UHMW polyethelyne is what the Adair tracks are made from....it will wear out eventually, but if the rollers roll, it will take a long, long time. OR: The stuff is cheap enough....just replace them when you replace chain if you are worried about it.
      • #18
        Hi. Can someone tell me what size that U Channel steel is that is being used here? Also, where can you find that?
        Thanks!
        • #19
          It is standard unistrut, 7/8" tall, std. is approx. 1 5/8 wide. It should be available at any industrial supply, bolt supply store or McMaster-Carr
          I bought everything from mcmaster carr.
          • #20
            Thanks!
