I'm curious if anyone else has had any problems with the approx 4 foot long transmission pusher rod (if that's the correct name?) which extends from the shifter lever (near the front seat) to the rear transmission linkage. Mine is bent and bows excessively when I try to shift. It was in this condition when I bought the machine(used), and while I've pulled it out and straightened it a couple of times now, it immediately bends again upon usage. The hollow metal tubing has either weakened over the years, or was too soft to begin with... or maybe the transmission is too sticky and putting too much pressure on the pusher rod. At any rate, it makes it pretty difficult to engage Forward or Reverse.
I'm curious if anyone else has had this problem and what they did about it. I'm considering trying to straighten it (again) as well as possible, then weld shallow u-channels down it's length to reinforce it one or more sides. But I have two problems...
1) My 6x6 is far away at my cabin so I can't check what kind of clearance I have, if any.
2) My welding experience is limited.
Any ideas or suggestions?
