I purchased and installed a Rec Industries roll cage kit on my Max today. The kit is fairly straight forward to install even though the instructions are a bit lacking and I had to enlarge a few of the upright cross bolt holes a bit to get the through bolts to line up properly.
The question:
The seat belt installation section referred to illustrations that were not printed on the two page document. They also indicate that I have to drill the lower tub to connect the seat belt support rail.
Even though they supply fender washers to prevent pull through, I don't relish adding any new holes in the plastics if I plan to float it (I know I can add some sealer and I do have a bilge pump installed). I question the strength of this arrangement, as the seat belt bar is not connected to the metal frame rail as I expected. I could always run over to a local racing harness manufacturer (RJS) and have something custom fabricated for this application, but I would still have to figure out the inboard mounting points for a side by side installation.
I am also wondering how/where the members (who installed a suspension seat) attach a seat belt, as you can't bounce in a sprung seat with a cinched seat belt across your lap.
My truck fleet have the belts attached to the suspension seats, I assume someone figured out they needed to do the same on their Max machines.
Any pics would be welcome!
The question:
