Some time ago i had mentioned that i would post the progress of my conversion of a Buffalo to a 2 seater with a smaller flat deck,
well here goes
Before i started
first you have to remove the deck and all the bolts that hold it on, do not remove the deck stands,
then remove the front seat to get at the front deck bolts, don't forget to remove the trans shifter rod
remove the front deck stands only, you won't need it anymore
starting at the front stake holder ,remove exactly 18" of the outer frame side rails, and cut the cross rail from the piece you remove ,you will need it later, refasten the frame together again with all the bolts nessasary, to make sure everything fits when you weld it together again
this was a good cut, and fit nicely, make sure you gouge the weld joints for better weld
well here goes
Before i started
