I have a manual marine windshield wiper that will require slightly larger than a 3/8" hole to install.Does anyone know how far the windshield glass sits in the frame? and Has anyone here ever had a hole drilled in the glass by a properly equipped shop? I can tell you there isn't much of a chance to install a wiper and I have never seen a picture of one in a Max II.
Installing Windshield Wiper
Eldon,
I don't know about you but my windshield which is a stock '78 frame is plexiglass if yours is as well you can use a hole saw for wood to do it. Last time I drilled plexiglass with a hole saw I taped around my hole with masking tape and drilled in reverse so it didn't eat up the glass and crack it. It worked well for me but like I said I was drilling plexiglass and 3/8 is a small hole so you might just want to use a normal drill bit once again if said windshield is plexiglass and not glass.
It's not difficult to figure out whether it's glass or plastic.
Originally posted by Eldon View PostIt is glass I believe ,gopher.
Originally posted by Shawn H View PostI have drilled in pg and found the best way is to run your drill backwards and take your time.Last edited by Mike; 03-17-2011, 05:16 PM. Reason: merged two consecutive posts. You can reply to everyone in one post by using the multi quote button.
If it's glass I have no idea what to do then besides to actually purchare a glass circle cutter and maybe a rubber grommet and cut it yourself. If that's the case I would just see if i could get the piece of glass out of the frame and cut it with the glass cutter then measure and mark the frame and drill it out then pop the glass back in and silicone around it. I just can't believe that yours is made out of glass though I think that's silly considering it's there for protection from elements/debris.
those ARE glass and they are covered by about 3/8th inch of frame so it is unlikely that there is enough meat left to drill safely through, I would think about a building a plate above the frame to mount the wiper through, and just mount the plate to the edge of the frame with 1/8th bolts as close to the edge as possible, but you would have to see if it can be done with your soft top. you may have to sew a divit into the soft top to go around the wiper bracketHe who has not cruised the back country in a 6x6 , has not lived life to it's fullest
