Heres some images, the transom bracket of the minn kota actually conformed to the back plastic lip of the trunk area of the MAX quite nicely.. Of course it needed stabilization so i bolted in a thick board & put the transom bolts right through it.. It is so secure you can barely rattle the motor, very solidly mounted.. Got an 500gph auto bilge installed & kayak screw-in plugs, everything marine 5000 siliconed.. Hoping this will give the MAX ability to travel in the river by me which can have a current during tidal interfaces.. I am guess between the 55lb thrust minn kotta & the tires, i can make about 5mph.. As long as the motor is running, the battery will be charged.. I am hoping the stock battery in the MAX will suffice.. Any problems i always have the "pull start" option..
Can anyone aswer me this: While waterproofing this MAX i notice that where the exhaust pipe exits the plastic chassis of the MAX motor box, I see daylight!, there is a clearance around this pipe that will allow water into the hull.. I am sure all MAXes are like this, but water can easily get in there?? Is there any way of sealing this?? taking into account the high temp of the muffler & the non-adhesive properties of the MAX plastic body.. Can this be a problem? or does the MAX sit high above this in water??
Havent tested her in water yet, but hope to in a week or so when i get a trailer.. speaking of trailers.. a 5x8 ATV trailer will work for a MAX correct??
~ Sumpcommander
[IMG]
[/IMG]
~ Sumpcommander
[IMG]
