Steel frame around Max IV
  • Steel frame around Max IV
    I want to run the angle around the front and rear of my Max IV just like the angle used on the Factory Rops. There is not a standard angle the size used on the ROPS. what are you guys using for that frame? I have noticed alot of people doing the same thing. I also would like to add a bumper. Any suggestions?
    I used 2" x 1.5" angle and it fit great. I put the 2" section on top.
      I just fabricated this winch mount integral with the front bumper as a replacement for what I built a a couple of years ago. The bumper is a continous piece of 2-1/2" x 2-1/2" x 3/16" steel that wraps around to the sides. I'ts heavy but I need it for the trees and brush that I go through. I will be added mounting points for my full cage and other goodies when I get around to building them.
      Max 6 Wheel Drive
        Argohunter, that looks really good! Here's a picture of mine in the gallery:
          I didnt think 2.5 X1.5 is a standard angle size is it? I dont think the size on the Max Rops can be matched can it? Argohunter I wish I was at good at fabrication as you are. That looks great.
            Isn't the Max ROPS 2" x 1.5"? I'm pretty sure that I just measured the Max IV, went to the scrap yard and found the same size for my Max II. I can measure again to find out for sure.
            Edit: 2" x 1.5" is a standard size for unequal leg angle iron: Jersey Shore Steel Sizes & Weights
              I think that is the right size. I was thinking I looked it up in a steel book and couldnt get that size that small. I guess I was wrong.
              thanks Eddie
                That's a nice looking cage you made Mike. Looks like you imagineered it just right! I like the way you painted the steel frame on the tub lip to match the body. I had to look close at first to see how you mounted it on. Did you replace the original hex cap screws and wing nuts with something else like longer ones or did you use the original ones?
                Max 6 Wheel Drive
                  I did replace the wingnuts. I'm now just using regular nuts and bolts and the bolts had to be slightly longer.
                  Also, Eddie emailed me to ask about the thickness but I forgot about it until I saw this post again. I believe it was 3/16" thick Eddie.
                    How much of a job is it to get the tub open? Do you use some type of lift to raise the cage up and off the Max or can you lift the combined weight of the upper tub and cage as one would normally do, allowing it to hinge at the front of the Max?
                    Max 6 Wheel Drive
                      I still leave the bolts at the very front attached and just raise the cage and the body up at the same time. The stock body prop still holds the weight fine. It's really just like it was without a roll cage.
                      The only part that really changed is not being able to open the body without tools. I now have use a deep socket and a wrench.
                      Also, if you take the cage and upper body completely off, it is a little difficult to get everything lined back up again. As long as you leave the front bolts on and just prop it up, it's no problem.
                        does anyone know the gauge or the thickness of the angle used on the Max Roll cage? I think im gonna have to have some angle bent at a sheet metal shop.
                        Eddie
                          Eddie, I think I posted it a couple of posts back but it is 3/16"
                            thanks !
