Hello Folks,
I have just purchased a used Max IV, everything worked fine for a day and then I started it up and had no steering. The machine runs forward and reverse but when you pull on any handle it seems to want to turn but then just stops (the engine does not stall).
I consider myself pretty handy with a wrench but I don't know anything about this transmission other than the theory of braking one output to make it turn.
I thought about checking the fluid level but I need to find a square wrench as the plugs are in very tight. As a suplimental question, does the engine have to be removed to work on the transmission? I don't have a problem doing that but I don't want to be making extra work if it is not neccessary.
Thanks in advance for any help or suggestions.
Dave
Dave
