hi, new max ll owner. Where would be the best and cheapist place to get an owners manual? the maxxll has 200hrs on it, the chains and sprokets look like they are almost new, what is the best lube for them? Some does and donts with this aatv would be welcome advice for this new owner.
little maxll info needed
You can get the owners manual directly from the factory. Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511 They're very helpful folks there. Any standard chain lube will work for the chains. Check to make sure there is 1 quart of clean ATF fluid in the transmission, keep the bearings greased, and keep up on engine maintenance and you'll be in good shape. Oh, and don't forget to put the drain plugs in before entering the water, you'd be surprised how people forget the basic stuff sometimes!"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
