max 4 help
  • max 4 help
    whats the best place two put my jack when jacking a max 4 off the floor.. dont want two break anything.
    Are you using a traditional floor jack with (about) a six inch pad on top? You can jack right up against the skid plate on the front or rear of the machine (if you have them). If you don't have skid plates, just put a 2x4" or similar block of wood on top of the jack pad to disperse the force a bit.
      I always error on the side of caution and always put a piece on plywood between the jack and body. the bigger the piece, the more weight is dispersed
