Modified Max II Engine cover
  • Modified Max II Engine cover
    The one thing that has always driven me nuts about a Max II is having to open the entire body to work on anything rearward of the Jack Shaft. I've had a solution in mind for a while and a freebie body scored from another member finally allowed me to do it. There are lots of possible ways to do this, but I wanted the machine to remain as close to stock looking as possible.
    With the stock access hole, about the only things you could do were change air filter or check oil
    The first step was to cut the entire rear section over the engine out of the donor body. I cut this as far as possible to the outside of the upper lip
    Then it was time to cut the actual body of the machine. This cut was made on the inner edge of the upper lip
    This shot shows how much more room there is to get in there with the modified cover
    Once both pieces were cut out, I laid the piece removed from the machines body inside the donor piece to transfer all the holes and slots (hard to see in the pic but it's in there). Once the holes and slots were cut, I laid the cover in place to check for fit, and drilled the mounting holes
    I wanted to use 1/4 Turn fasteners, but couldn't find any long enough. Instead, I used 1/4-20 bolts run up through the body. The donor piece has 1/2" holes that sit down over the nuts. The new cover will be held down with a fender washer and Wing Nut on each of the bolts
    Once the mounting was done, I took the cover off to final trim, and mounted the exhaust duct to the donor piece
    now I have he option to open the small cover for engine servicing, but I can remove the big cover to adjust/ lube chains and to clean the machine, without having to open the body
    I still need to pick up some shorter bolts, and 8 wing nuts, but here is what the final product looks like. I may try running some edge molding around the donor cover to see what that looks like
    Looks great Race, just looked at all the pictures in the gallery. I like it!
      I think it's a great idea and well done. I even like the idea to trim out where the rollbar would have been. Did you think about putting a hinge on it? Just more curious if could be done.
        I would love to have put it on a hinge, but in my case there is no direction that it could swing open without hitting a bar. Standing at the rear of the machine, I have to lift the right side, slide the entire thing right so that the exhaust duct clears the body, then rotate the right side forward...
          Nice work. One of the things I dread doing when we get back from a ride is opening the Max II body to clean it out. What a pain that is, or in your case, was.
            Perfect use for the old junk top
            They are hard to find and a little pricey, $35 for 10, but they work great.
            Last edited by thebuggyman1; 07-13-2011, 09:53 PM. Reason: First picture didnt work
              Race, that is the same basic clip that holds the Avenger hood down. The one Jim(Buggieman) has in the picture.
                I had to special order the zeus fasteners I used on the green maxI[ATTACH]7133[/ATTACH]
                I had planned to use Cam-lock's but didn't have any long enough. I may upgrade it to the Zeus fasteners at some point, but price kept me from doing them right now
                  Great Idea.
