Hi All,
i have an idea but don't know if it is worth the time and coffee i'm spending on it. i have a 2003 Max IV, 25 HP Kohler, 25 inch wheels. I put a frame/rack/roll cage on it last year - 1 1/2' square tubing. The cage sits on two pieces that run the length of the body and are joined at the front and back by angle iron. Yes, its heavy duty but works really well for hauling, pulling in the bush, etc.
i've read the posts that say the seat belt mounts on the Max are essential as they provide frame support to keep the body from sagging. I'm wondering if I can strengthen this support by welding an extension on to the seat belt bar to run it (between the body seam) and connect to the rack frame. Then drop two pieces of metal down from the seat belt bar and connect the bar to the Max's frame. The idea is that is that i use the connections to the body frame and the rack frame to increase the body support the seat belt bar provides. I would do this for both the front and back seat belt bars.
Does this sound worthwhile or unnecessary?
