i am new to this. is there a aftermarkt plugs for the body
plugs
freeze plugs work in a lot of applications. screw type kayak, or jet ski plugs are also a good option... depends a lot on the type of machine your working onA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
ya know, this may be a good idea..i keep buying them damn bait well plugs at trader horn, ya know...them kinda that got the little tab you flip over and they release..well lemme tell ya..those nifty little plugs get caught on EVERYTHING! ive lost 4 already..lol, and i refuse to buy more so i just aint had it swimming in a week or so.. (not to mention currently down due to gasket failure..) but ya..capplugs might be the answer!! cheap, easy, etc etc! hell, i bet a dab of glue would keep em in rather nicely! lolOriginally posted by thebuggyman1 View PostI use caplugs Caplug - Assortment because they are CHEAP!I have officially caught the 6-wheel-sickness!!
In that case, like thebuggyman1 said, it's hard to beat caplugs. That's the factory plugs and they fit so well that they are often hard to remove without damaging them (which is fine because, like thebuggyman1 said, they are cheap). If your drain holes are messed up or elongated, you can drill them out to the next size caplug. That's what I did on my Max II and it works great. If you will use the search, there are several threads on them along with a part number and links to where you can buy them. Here is one to get you started: http://www.6x6world.com/forums/max-a...lugs-stay.htmlOriginally posted by buffordb View Posti have a max iv
I use the same factory caplugs. I also carry a pair of pliers in my storage tote which I attached to the back of the machine.
I also thought about getting something like these:
McMaster-Carr
I'd have to measure the hole to find out which one would fit though.
I have enough of the caplugs to last me for a while anyways.
Mine look just like the pic. I believe them to be std. issue from Argo. I install them from the inside out.They're a little more work to access but no worries about them catching on something and accidently releasing.Also, if they do fall "out" they would still be in the machine,available for re-use.
Joe.sigpic
These are the one's I use you just need a small wrench (which I carry with me) to losen and remove them.
McMaster-Carr
