It is probably the plungers in the T-20 popping back into their bores. a common thing on The newer T-20's and nothing to be too concerned with. A lot of times this can be felt in the sticks so that's where associate the sound with. just to be sure, remove the seat/ floor and watch the plungers on the transmission as you work the stick back and forth. you will probably see one or both of them not move for a split second as tenson is taken off it, then pop back in toward the trans. If that isn't it, let us know and we can dig into other possibilities
I believe I can "+1 that" also. Cut the second o-ring grooves in the plungers for the t-20 I rebuilt and installed in my Attex using(for now) the existing linkages. Not sure if it's the added "resistance" they offer or just the sloppiness of the u-channel type levers on the trans but the "clicking" is liking to make me crazy. Got a t-20 w/ "tounge depressor" type levers that shall soon be overhauled then installed in the Attex w/ nice spherical rod ends,precision shoulder screws,etc.,etc., to provide a nice "tight" feel in the sticks and attempt to quiet it down a little.
