Not much room in the garage with Max II and the other toys. Max being the hardest to just push around has anyone tried putting wheel dollies under 4 or all 6 wheels ?
Thanks, Pony Soldier
That sounds like a really good idea. I know that Harbor Freight Tools sells some dollies that are pretty inexpensive. I bet those would work out very well.
Four will work and you can make them with a board and some wheels from the hardware store. Since the vehicles weigh so much less than a car, a person doesn't need steel or metal. Just a 2x12x12 with a hole in each corner and some wheels off and old chain with rollers, or like I mentioned some from the store. If you make them to fit under a milk crate you could have it roll around and have the wheels off the dollies so you could do drive train work.
Jerry brings up a good point about making them yourself and that sparked another idea. What if you just build a rectangle frame out of wood that the 6x6 could drive onto. Then just put four wheels under it. That way you only have to buy a total of 4 wheels (one for each corner) instead of 16.
