MAXIV clutch identification
  • MAXIV clutch identification
    My 2001 IV makes awful noises in turns and reverse.Pulled the drive cluth,it slid off the shaft with ease.I can't find one anywhere that looks like this one.It is worn and corroded badly.Looks like replacement is best approach.Please help with ID.Markings on clutch-Comet/Salsbury 6/0,assy no.3024700 "DEEH"
    I have a new comet Clutch that I got no need for. U you get it for $200 plus shipping. its fits all standard 1 1/4 shafts. I got it to be able to handle higher RPMs but figured out the rev limiter is doing just that so no need for it.
      Maxiv clutch
      CBASS, THANK YOU FOR YOUR SERVICE.
      My MAXIV has a 16 hp. Vanguard engine with a one inch drive shaft.Are you sure your clutch is 1&1/4? "DEEH"
        you right. It might just be a 1'' Ill check once i get home. It was on a 16hp Vanguard and a 20hp Vanguard from 600 Racing.
          Maxiv clutch
          CBASS,
          Please advise identification info. stamped on ramp plate hold down tabs[ASSY NO., MAX RPM, ETC ].
          thanks, DEEH
