Is there susposed to be a gap between the flex pipe and the body because mine does and i though water would get in? So i was thinking i could close off the hole and routed the flex pipe out one of the openings in the back where i would put heat sheild then a chrome out let. Would that melt the body or does anyone have any better ideas? Thank you.
Custom exhaust for max 2
Here's a link to R.I. website. It's a picture of how the exhaust exits on the new machines. Sorry but I couldn't find any pics of the inside of the tub. http://www.maxatvs.com/clientuploads...ax2_c_out5.jpg
You should have a triangular fiber spacer around the exhaust pipe. The holes get enlarged over time. I dont know what material they are or if they are available from the factory.
Your exhaust may be 6-700 degrees there so it will melt the HDPE tub. If the gap is small silicone will last for a while.
You can get the triangular fiber spacer from the factory still but that exhaust system is not fun to take on / off. Before I converted mine to a rear exhaust I had a similar problem with the gap around the exhaust but it really didn't let as much water/mud in as you would think. If you want to seal it I would do what buggyman mentioned and just use some high temperature silicone.
