Max II upgrade
  • Max II upgrade
    Max gets teeth........ Mount from Richard at route6x6.com and winch from tractor supply. Easy install. cost $175
    Looks good! You will be so happy that you put that winch on there when you're out in the middle of nowhere by yourself and the machine is burried in muck over the tires.....plus it makes the Max look really tough! I really like the way the winch with the 22" Rawhide III's and the round headlights and brown body go together too.
      thanks Jeff, I see you got another "Project" today. Jim (Pony Soldier)
        I like your winch. I have the same one on my Argo. When I am running around, I have found it alot easier having the remote attached to the zipper pull on my coat when I need to operate the winch, as opposed to hanging on my key chain with the ignition key.
          Jim, I certainly did get a new project thanx to the tip from Hydromike. It is actually a really nice machine that has a lot of potential.
