After Mikes article, I decided to investigate the water leaking into my Max IV which has 60 hours on it since new in Oct 07.
I put it in the water and sure enough I could see water dripping in at each axle.
After removing the wheels I turned the axles just to look. I noticed that my bearings were spinning in the flanges/races on four of my axles. Shaking the axles up and down revealed movement of the whole bearing in the flange.
When I removed the locking ring and unbolted the outer flange, I was able to pull the bearing out onto the axle. I could see that the bearings and the flanges now have some wear from the spinning. Also had evidence of water gaining access arround the outside of the bearing.
On reassembly I coated the inside flange with ultra grey gasket maker or "Honda Bond". This is where the bearing seals on the inner flange. Put everything back together and it seems the to on less water. At mid-ride yesterday it did not look like the bearings were spinning in the flanges.
Any comments and or suggestions you guys have would be great. For newer Max owners make sure that this is not happening to you.
Locking ring question for the splined axle Max IV. It seemed to me that I could lock the bearing tighter to the inner flange by tapping on the locking ring/collar prior to locking it with the set screw. Without setting the bearing tight against the inner flange, I was still getting the bearing spinning in the flange.
Thanks,
Rutledge Fuller
Thanks,
Rutledge Fuller
