What is the secret to greasing the inner-bearings on the front and rear axles of a Max lV? There does not seem to be enough room for the grease gun to access the grease fitting. What is the solution? Thanks
How to grease a Max lV?
I went to NAPA and bought a side mount grease gun tip for those bearings.Originally posted by djack41 View PostWhat is the secret to greasing the inner-bearings on the front and rear axles of a Max lV? There does not seem to be enough room for the grease gun to access the grease fitting. What is the solution? Thanks
Actually what Mike said....a 90 degree tip.Originally posted by djack41 View PostWhat is the secret to greasing the inner-bearings on the front and rear axles of a Max lV? There does not seem to be enough room for the grease gun to access the grease fitting. What is the solution? Thanks
