I bought a 99 Max 2 for my daughter and have started replacing axle bearings. It has splined axles with set screws. Had to drill out one of them. Has anyone switched them out with stainless. They shouldn't seize and they're only keeping the sprockets alignment from side to side. Shouldn't be any shearing problems should there? Second question, front axles were bent from my son driving it like a rental. Straightened them the best I could on a press. Can you swap the fronts to the middle or rear just to get fresh ones up front. Hopefully someone with more brain cells can help me out. It was a rough New Years Eve. Thanks Mike D
Max Axle Questions
