Ok, I got to see and run this Max IV. There wasnt any water around to water test it. The owner said it didnt leak. But I already did that trust thing when I bought the Hustler and,... well thats a total rebuild at this stage.
Anyways. When I looked under the floor boards. I never in my life ever seen so much grease! It wasnt hardened or gritty looking. It was just loads of black grease. Looked to be an inch or two deep on the floor.
Since Im familiar with the axle and frame layout of my Hustler. I found myself a little lost looking down in the Max. I need to see a picture of someones Max that they are redoing. The owner said that the Max is a 1999. He mentioned that the tires are stock original and they are the 12x12x26. These tires looked serious compared to the 21's on my Hustler. He said it swims and steers in the water very well with those tires. I was surprised to see that the engine in the Max is set up so high within the body. I wonder why they did that? Also. The tub drain holes. He showed me there were 2. Im not sure I understand Max's policy with the plugs or even the owners comment on them. Saying that the plugs arent reusable. That doesnt make sense. This thing needs to have all the excess grease removed. Like I said I could not see in the bottom where the drain hole or holes are.
I also noticed that you had to ease the shifter into gear, (forward or reverse). Meaning it wasnt a clean process. I dont know if it's an adjustment or if it's a tell tale sign. The engaging didnt grind. It just wasnt a smooth transition. Anyone wanna chime in on this?
How about some links to pictures of the inside of these.
RJ
RJ
