Max II width?
  • Max II width?
    How wide is a Max II from wheel to wheel?
    56" with the 21" rawhides.
      heres a good link w/dimentions of all three models Google Image Result for http://www.campbellssmallengine.com/jmax2specs.gif Weight: Approx. 670 Lbs. (305 kilos)
      Gross Vehicle Wt: 1270 lbs (575 kilos)
      Gross Permissable Wt in Water: 1170 lbs (530 kilos)
      Length: 86 Inches (218 cm)
      Height: 37 Inches (94 cm)
      Width: 56 Inches (142 cm)
      Wheelbase: 50 Inches (127 cm)
      Seating: 2 Persons
      Fuel Capacity: 5. U.S. Gallons (19 liters)
      Transmission: T-20 Skid Steer
      Main Drive Chain: R.C. #50
      Final Drive Chain: R.C. #50
      Axles: 1 1/4 inch heavy-duty steel.
      Towing Capacity: 1000 lbs. (454 kilos)
        I've got the dimensions and specs on my website too, just look under the models.
          Recreatives does claim both vehicles are 56" wide. I measure the Max II at 54" and the IV at 56". In fact, I have driven the Max II between two trees where the Max IV wouldn't fit. Good to know when millimeters count!
