WHY WHY WHY WHY?!!??!!
My max with factory rubber tracks and track kit w/5'' extenders.Solid axels with support channel connecting all 3 wheels. Tracks have cut an immense groove through the rear of tub on both sides !!!
All axel bearings are good no movement in axels at all
There is at least 3 1/2'' between tub and track. The only thing comes to mind is when torquing a hard turn the the tires give on the side walls enough to bring the track to close to tub
All tires are at 4 1/2 #'s of air and holding on rim just fine. If this is the way it is going to be......anyone want a Max???
Only riding I have been doing is a little plowing around the yard !
Next question .......can the tub be welded back together and how?
Only riding I have been doing is a little plowing around the yard !Next question .......can the tub be welded back together and how?
