I am getting desperate......
Shortly after purchasing my MaxII I ordereds a Track Kit from a dealer.
After installing all the gear, I keep blowing out front tires. I am using 21" goodyear Rawhide III tires. I have inflated them at 2.5 PSI, 3.0 PSI, 3.5 PSI as well as 4 and five PSI.
Same result each time I break bead and track comes off. If it is not the left front it will be the right front. But one thing for certain, one is comming off.
What ideas, troubles, experiences do any of you have which could help me to determine problem.
I have sent msg to RI looking for measurement of track to be sure they are not too short. I do know that when I install them, I take centre tire off, remove valve stem from front and rear, strap around each tire colapse each tire and they are still very difficult to put on.
I do kinda think they are too short and wonder if a couple of inches would make a difference.
Suggestions would be greatly appreciated.
Oh, and I read one article here this morning and the suggestion was made that with tracks the front drive chain is removed?????
Is that a fact, should the front drive chain be removed?
Moike
Moike
