Does all the Max II s make popping noise even when your going straight. I replaced all the chain and adjusted it with the tires off the ground.It sounds like a bull doser running on tracks. The left chain adjuster looks as if it sticks out to far, the bottom chain almost rubs it.The right side has good clearance. If i slide the sprockets over the chain would rub the tub. This is my first 6x6 and was wondering if they run quiet or if they made alot of noise.The bearings have a little play mabe 1/8".
Thanks for your help guys.
