I recently bought a 2003 Max II. After coming to the realization that the popping noise is not normal (as the PO swore it was), I learned how to tighten chains and replace a master link. I also learned that throtlle cables will freeze and even the slightest tug on the handle will snap said cable. It has definitely been a learning experience. I plan to use the little Max mostly for hunting, so I would like to add some auxiliary lights and some sort of rack on the back. Any advise would be greatly appreciated.
New To The Max World
Thanks Tony I'll look into those. I am thinking two foward and two rear facing lights should be plenty but part of me would like to go all in and have a light off both sides as well. I guess my biggest question is how many lights can I mount and still have the battery charge? Is there a need for dual batteries? Is there an upgrade for the charging system? Again I am very new to ATV's and don't even know for sure what questions to ask.You may all go to Hell, and I will go to Texas -- Davy Crockett
It is very easy to add an alternatr. Just make sure you add a flipper switch.I added a pulley to the fan side of my 18hp Briggs. I can now run anything and I do. I also hunt with the Max ll. I have a heater fan, six lights, power point and biladge pump. This spring I am adding a dome light and radio. I do not worry about power. Oh yes a winch as well. If you have any questions p.m.me.
