I'm trying to replace the bearing on the front left of my Max II. Is the brake disc held on with a set screw or is it just pressed on? The axles are splined and I don't see a hole for a set screw. It looks like something was rubbing in the area a screw may be and has kind of "ground" material over it if it is there. Any suggestions? I have searched and read the write up on bearing replacement..Thanks for the help.
2001 Max II brake disc removal
Buffalo Bearing will be cheaper than that.......but next time I need bearings I will get them from mudd-ox. Matt says his bearings are true triple seals, not the labrynth seals of alot of that type ag bearing. The mudd-ox is MUCH larger and heavier than a tiny little maxII, and if his bearings hold up on that machine......
