I own a max11 23hp kolar can anybody tell me how a set of tracks would work on sand dunes as I do a lot of driving to surf beachs there are a couple of hills I have to winch up also how durable are tracks as I have done 250hrs in 9 months thanks
Tracks on max11
Tracks make a very big improvement in sand and other types of loose soil. Max II 's are going to require the use of a smaller than normal tires. The factory rubber track kit uses 21" tires. Factory rubber track kit recommends the use of additional 3rd bearings and additional frame reinforcement components. Factory rubber tracks move the tires outward several inches.
Factory rubber tracks seem very durable, but any track setup is not going to swim well due the requirement of small tires.
Best of luck and hope this helps you a bit.
