I'm in the process of rebuilding my 89 max two and got the axles back in it today. Putting the new chains on though is really really tough. I had a chain tool to pull them togethere and still couldn't get the chains to connect. Finally took the adjuster off and connected chain. Had to force roughly the roller adjuster back in. ( I bought roller style chain adjusters btw). Now the chain from the front left axle to the center axle is on. But it is really tight. It only moves up and down some. It is difficult to turn the axles togethere. Will over the first couple hours the chain stretch? And loosen up some. There was very little possibly of installing chains with adjusters on. I will have to remove the adjusters, install chain, and then reinstall adjusters. Any input or ideas?
And chain is correct length. 51 links. 52 links and it's to long and chains hit. 51 links and it's a tight as the cables the hold power lines up.
