I have a 96 Max IV with 20hp Kohler Magnum. From all I've read this machine should have some muscle to it on low end. The engine is strong and runs great, but can't get up any kind of half steep slope. It just feels sluggish or maybe like its slipping as I build speed.
Max IV has no low end power. Need help!
It sounds like the typical belt loose/worn/not adjusted properly issue. It could also be your clutches not engaging properly. Try lubing them and you might even need to replace the driven clutch spring if it's worn. This should fix the problem. The low end is where these machines really shine, especially with a torquey 20HP Kohler."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
I made sure to push sticks forward as I drove, but can't tell difference. I noticed the clutch pulley on the tranny is rusted pretty bad on where the belt moves in and out of it. This has got to create a problem I would think. Could this heavy rust slow the belt from traveling on it?
Originally posted by Richoshez View PostI made sure to push sticks forward as I drove, but can't tell difference. I noticed the clutch pulley on the tranny is rusted pretty bad on where the belt moves in and out of it. This has got to create a problem I would think. Could this heavy rust slow the belt from traveling on it?"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
