After having my Max IV in the garage for four years i'm finally going to get her going.. First thing is to remove the Kawasaki ta 440a and install my Briggs 18hp V-Twin!.. Any suggestions or help will be appreciated. I guess first thing will be to figure out how to mount the engine onto the old stand..
Finally going to do this thing!
Make sure you set your 18HP Vanguard up with the proper governor spring and change the driven clutch spring on the T-20. A call into Recreatives should get you the parts and any other advice you may need. Good luck with it and keep us updated. Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511Originally posted by chrisivins View PostAfter having my Max IV in the garage for four years i'm finally going to get her going.. First thing is to remove the Kawasaki ta 440a and install my Briggs 18hp V-Twin!.. Any suggestions or help will be appreciated. I guess first thing will be to figure out how to mount the engine onto the old stand.."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
