I dont think splicing off a line to a motor is a good idea. Do you have a hyd schematic for your vehicle? Generally when you want to add a device to your sys you start at the controls. A valve body, adding one more 4 way valve to your existing valve set up. Or if it is the type that you cannot add to, pull it out and add one that has one more valve in it. Exchanging a two valve for a three or a three for a four. Then you can add the hoses to your winch from this new valve.
