Most of you guys know I have owned several aatv's. One of my favorite was the old Cushman Trackster back in the early 70's. It didn't float very well, but was heck of an old swamp runner.
Since then I owned a Hydro Traxx for a few years. It was a very tough machine and I liked it very much. The high whine of the Generac engine drove me nuts, but it was also a very tough machine. I understand the new units have a bigger engine and are not as loud.
The most impressive machine that I have driven is the Mudd Ox. I don't own one yet, but I can't wait to get my hands on one.
I test drove one recently and found it to be about everything that other Hydro static machines are not.
I like the larger engine with the CVT clutch. It will allow me to putt down the trail at a lower rpm. The external braces on the axels will tie all of the axels together for much more strength. I carry moose and I believe it will do that very well.
I like the center engine for better balance and a better "pivot" point while going over logs and up sharp banks. In my experience, the 8 wheel units have a greater "traction" with more wheels on the ground when going over sharp banks, logs etc.
I especially like the fluid drive when going through swamps. When turning or if one side bogs down, it is easy to add more power to the bogging side rather than having to brake to turn. Momentum is EVERYTHING!
I could go on for days, but I think that Matt at Mudd Ox has designed one heck of a machine.
I live in an area that requires a machine that will hold up under sub-zero as well as gruelling peat bogs, and carry heavy loads. I believe the Mudd Ox will keep me from having to walk out.
Bubba
Bubba
The Hydro Traxx 6x6 is a well built machine , but like you Bubba ,what turned me off about it , was the constant loud whine of the hydrolics. The CVT design of the Mudd Ox allows you to drive slowly through the trails with a lot less noise.
