Looks like a really nice ride. I have some questions though..
Is it fuel injected ?
Is the whine i hear from the hydralic motors ?
What is the ground clearance at the bottom of trough ?
Is there a skid pan?
What type of drain plugs and acess if any ?
What is the altenator output?
Is the winch tied into the frame ?
Do they have bearing extenders ?
when on water can you get to the back cargo area ?
A list of pros and cons between the Avenger and Mudd- ox would be great for new buyers..I think the Mudd-ox may out climb the Avenger in the most demanding situations but may lack in ease of use on the trail and on water.
Tracmaster
Tracmaster
thanks for your comments regarding the Mudd OX and would like to concur with your replys. I would like to add my 2 cents worth as well. The Mudd Ox has all the makings of an exceptionally heavy duty undercarrage in comparrison the the competition. Matts axles are molly crome with bearing extension housings on all axles and support three bearings per axle. One inner, one mid and one outter on the extension housing. If the vehicle is to support tracks there is another support rail which ties all the bearing extension housing together. The Mudd Ox is not fuel injected at this time which makes repairs in the field much easier. I have been in the automotive repair business for 40 years and worked on the first fuel injection systems as well as computer systems and for my part on these aatv they do not need to have a computer in the inviroment they are designed to operate in. The 40 HP Kohler has a standard 25 amp charging system and has been more than efficent to handle all systems on board at this time.I am sure that higher charging rates will come about as the needs for the commercial market changes. Matts machine does not have a full skid plate as we speak but is nearly finished and ready for production. The integerty of the lower hull on the Mudd ox is much heavier than the Argo.
