I have had my Mudd Ox for about a month now and must say I am very pleased with it. It is built like a brick outhouse beefy and stout. This is my first AATV but not my first experience with them. Have a couple of buddies who run Argos so I am not a complete novice, just a wet behind the ears rookie.
So far the Mudd Ox has performed extremely well handling the swamps, tundra and creeks I must cross to get the cabin I am building. I have used Argos equipped with tracks to get there in the past and did not have any more problems with getting stuck with the Mudd ox with out tracks. Found it to swim extemely well when crossing flowing waters. The hydro-static steering sure makes it easier when changing direction in the swamps and on the hills. It seems like I can keep my momentum going better vs the Argo. Yes I have been stuck, poor choice of lines on my part, stuck the Argos with tracks too.
It takes very little winching to unstick which is great as at times the only thing to winch from is a three foot black spruce tree in the middle of the swamp. It really has surpassed my expectations in its abilities. Now to be perfectly honest I have had one issue with it that is more annoyance but have had issues with it getting hot and vapor locking the motor. Cools off quickly and is good to go. This has happened on warmer days (for us Alaskans anyways) temps in the high 60s. The first time was on the intial drive out on the Knik river running flat out engine running at max and little stick movement. The second time was running in to the cabin again running the engine at max running flat out in the swamps with little stick movement. I have found that if you do not max the throttle and cycle the sticks it really helps but is not a sure fire fix. I have been working with Mark the local dealer who has been in contact with Matt on this issue. I knew when I purchased this machine that there probably would be hick ups and glitches just because this is such a newly designed machine. By no means is this issue a show stopper and I would make the purchase again. The question of speed has come up on different posts on the Mudd Ox I was able to reach just a tad over 20mph based on GPS readings with over 550 lbs of driver and passengers running on semi packed glacier silt.
Attached are some pictures of the mudd ox and the terrain that it has been used in. Thanks to Matt and his crew for building this work horse and to Mark, Travis and Ben at Alaska Mudd Ox for answering numerous questions and being a great bunch of guys to deal with.
Tinman
I will add the photos after I figure out how to shrink them. Still have not figured out how to shrink pictures so posted some in the gallery under using the mudd ox in alaska. Not the most computer savy person that you will meet.
It takes very little winching to unstick which is great as at times the only thing to winch from is a three foot black spruce tree in the middle of the swamp. It really has surpassed my expectations in its abilities. Now to be perfectly honest I have had one issue with it that is more annoyance but have had issues with it getting hot and vapor locking the motor. Cools off quickly and is good to go. This has happened on warmer days (for us Alaskans anyways) temps in the high 60s. The first time was on the intial drive out on the Knik river running flat out engine running at max and little stick movement. The second time was running in to the cabin again running the engine at max running flat out in the swamps with little stick movement. I have found that if you do not max the throttle and cycle the sticks it really helps but is not a sure fire fix. I have been working with Mark the local dealer who has been in contact with Matt on this issue. I knew when I purchased this machine that there probably would be hick ups and glitches just because this is such a newly designed machine. By no means is this issue a show stopper and I would make the purchase again. The question of speed has come up on different posts on the Mudd Ox I was able to reach just a tad over 20mph based on GPS readings with over 550 lbs of driver and passengers running on semi packed glacier silt.Attached are some pictures of the mudd ox and the terrain that it has been used in. Thanks to Matt and his crew for building this work horse and to Mark, Travis and Ben at Alaska Mudd Ox for answering numerous questions and being a great bunch of guys to deal with.
Tinman
Hey, arent I supposed to be able to have three passengers?
The biggest issue for me here in Alaska, is being confidant that a machine will get me back to the truck (all the wanging and banging in the argo drive train concerns me) the mud ox runs smoothly and makes a lot less noise. That said there are a few things that i think should be addressed. First the over heating issue has to be fixed it turns a 2 hour trip into a 4 hour trip if its 65 or warmer. The machine never fails to restart but waiting for it to cool down is a pain in the butt. has anyone tryed to ceramic coat the exhaust?
