What are the maintanance requirements on a mudd ox ?
Thanks Mitch
Thanks Mitch
). I had the carburetor adjusted a little, and the backfiring is less prevalent, but is still there off and on. You had said the electronic fuel pump would help hot start problems, but I have very rarely had issues with that and I think that will be even less on an event with the alternator/fan upgrade (as soon as I get around to it). So......if the electronic fuel pump upgrade would be primarily for hot start issues, I probably don't need it.
, and according to him he leaned it out as much as possible. There has been a noticeable difference in how it starts, runs and idles and I'm fairly certain it was definitely too rich earlier on. (it was also laying a little too much black around the exhaust). It doesn't backfire as often or as loudly as it did before.
, only time will tell. The only possible confirmation I have had of this so far is getting a new air filter, and he actually used a model off of some tractor that he said was nearly identical. If this becomes too much of an issue later on, I will try a different mechanic and see what his opinion is. Some of these local hillbillies know what they are talking about, and some of them don't. (not that I'm criticizing hillbillies...being one myself
....but it is what it is).
