6X6 Mudd-Ox
Of course it's not the same driving on flat ground. It's O.K. if you don't watch our AZ videos which are full of pea gravel sand hills just like the pic jpswift captured. The majority of the terrain we ride is either rocks or pea gravel sand. It's the nature of the state.Originally posted by Cougar View Post:
Driving on flat ground is not the same as going up a pea gravel hill. I have never see a pea gravel hills in AZ....
The Sand Dunes are even more of a challenge to climb than pea gravel. That's why I was wondering if the 6 wheeler made it up that hill. It should have been able to.
Bridget
Hmmmm, maybe you should read what I wrote again because you totally missed the point. I thought my point was pretty easy to understand and straight forward, but I guess it wasn't for you so I'll explain it again. I was talking about the terrain in the Southeast, never once did I mention the dirtbike or anything else about it. Try to stay on topic with the thread and not take things so personally. Your Mudd-Ox won't climb that long steep kind of hill with the loose stuff on it because it doesn't have the ability to turn high RPMs and build the speed up to get to the top of this kind of hill. Now put Whipper and Bridget's springers on that hill, and I bet they'd go up it because they have high powered engines that can turn the wheels at a significantly higher RPM than a stock 4 stroke or diesel machine. Put an Attex Thunderchief or Superchief on that hill with some Rawhide tires and I bet they'd make it up too. Good tires, high RPMs, and a good amount of horsepower is what is needed to conquer this type of hill.Originally posted by Cougar View PostFunny looking 6x6 just saying..."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
The hill in the video where Whipper was going up was a monster, George and i were there! That was a steep hill and at the top you had to shift right to miss the nasty rock at the very top. I am not sure but without suspension i don't think a factory machine of any kind could have made the climb due to the beating and knocking that occurred for the speed to be achieved to make the pull. The video did not show that but you can see Whipper moving a bit to the right. George nearly slid down the hill taking pictures and he was just squatting in the gravel.
Note: George and i made the climb also, and there was a pucker factor attached to that hill.
The Argo's have the same type problem due to the inability to get the speed up to help with take the hill.
I have went up some extremely steep hills with the Avenger but at the time i had tracks on it and was able to maintain traction.
Dunes: Well that is another thing all together. High RPM is required on any climb there, once the wheels dig in you are done. Never start off in a uphill position
mistake i made a few times. The Dunes were a blast but require a completely different set of driving techniques. Whipper, Bridget and WFO were great guides.
I am thinking from the 2 trips i have made to Arizona to ride the desert they any type of terrain that you can mention......except Mud.
That is a little hard to find out there.
Depends on how the machine is set up, as Lewis and Model Citzen have said a Spinger is awesome in the sand and at climbing hills, when I saw this video the first thing that crossed my mind was that the Ox was to heavy, if it was equipped with a set of Adair tracks it would have climbed the hill like it wasn't there. So many machines so many circumstances everything has advantages and disadvantages.Originally posted by mudslinger View PostWhy was the Ox having such a hard time getting up that hill? That quad pretty much put it to shame. Embarrassing.
