Ampihcat won't steer
  • #16
    Originally posted by thenewguy View Post
    The brakes are working and aint applied when the sticks are in the drive position, just won't release the steer clutches enough to get it to turn.
    If the brake was working properly, it would seriously slow the machine, and bog the motor when you pulled back on one stick while still giving it throttle. Is it doing that, or does it just keep going forward when the stick is pulled?
    • #17
      It bogs down like something is binding when you try to turn and if you really hit the throttle you can get it to jump side to side but its wicked quick and scary... i think that has part to do with the belt adjustment with the main clutch off the motor-trans
      but you really have to hold the sticks and it still hardly trys but when it does it jumps fast.
      • #18
        What I also noticed pull the sticks back is drive and forward is stop... Is that wrong?
        • #19
          so i figured it out..
          the guy that owed it before me had the steer clutches to tight i didnt know any better when i put it back together that i made them to tight...
          so figured that out and then
          figured out the brakes being applyed when driving in forward it needed more slack in the arm..
          so it all seems to work perfect in the air its to late now to try to ride it but i think its ready
