Lockley Wrangler 295
  • Lockley Wrangler 295
    I did a motor swamp on my Lockley Wrangler 295 with a rotex 340 snowmobile engine now i got a problem the double width chain broke and sheared some teeth off the gears every one but the tentioner. What can i use in the way of gear/chain ? If you have any ideas please help me I will take any advice!! Thank You !!
    Last edited by Mike; 11-17-2012, 09:40 PM. Reason: moved thread from tire forum to other aatv forum
    Welcome to the site. You can probably just replace the damaged parts and get going again. Most gears on our machines are nothing special and can be sourced locally through a bearing distributor or machine shop.
      welcome.
      we too have a wrangler.we have a build thread on here.i think your gunna have a tough time finding any new gears that will work.the jackshaft one is very small and the axle one is kinda unique.i have looked around the internet with no luck myself.search lockley on here,i thought i seen a yellow one that had a 41 chain setup on it with no tensioner.
