Originally posted by Don
View Post
spd wedge
That'd be my guess, but I don't know the Wedge machine well at all. One of the guys that's familiar with it may be able to tell. Lance?Stuck in the seventies- not in the swamp.
Okay boys I finally took some pics of the wedge project so here they are. keep in mind its a project that is in the beginning stages so it is a little "rough"
heres a couple pics of the engine, the engine mount and the mounting position itself
dismantling the Wedge
I was taking a look at the Wedge yesterday (after about 2 years of it sitting untouched)
1. Is there a way for the fuel tank to be removed?
2. I believe the entire drive assy can be removed as a unit, but I'm not sure. Can anyone confirm?
3. What's the easiest way to remove the drive axles?
4. I have soaked and soaked and soaked rusty bolts in a spray on lubricant...they aren't budging. Is my only solution to grind off the heads or is there a NASA certified rust eater that I don't know about?
5. Is standard 520 chain sufficient? Anyone know of a good source for chain?SPD FREAK
I can only answer questions 4 and 5.....
4. Grind 'em if you can. If soaking with something like PB Blaster doesn't work after a long soaking time, you can try a little heat on the nut if it's reachable without damaging fiberglass. You'll likely want to replace the nuts/bolts if they're that bad anyway. I like it when they break. Much less work.
5. Try Motion Industries. Do a search for "40 Roller chain" (I think the Wedges take 40, right?). If the search engine doesn't give good results, give the local branch a call. They're always very willing to help people out, and they have several chain options available to fit your budget. I buy mine in 50 foot reels. There isn't really an economy-of-scale, but you're left to break it where you want, rather than having 3.2 feet left over from each 10 foot roll you buy.
I just finished re-chaining my RIM with #50 Diamond chain. 8 Chains total, with about 35 feet of chain for the whole machine.. That's a lot of chain.
~msigpic
the entire drive train assembly is one unit which makes it easy to take out. I wish I hadn't thrown my old one away, but I thought I was the only spd wedge owner in the world at that time and new I needed to uprade. The axles should come right out if you have unbolted the carriages and the outside flanges.
as for the bolts, dont waste your time trying to free them up. just torch them off or grind them off or, I used a chisel on mine, my thumbnail grew back though.
you gotta get us some pics.
