Pulling Axle
  • Pulling Axle
    Good Evening all trying to remove a wheel axle off a hydraulic motor on my Hydrotraxx there is a clip on the axle does any one no if it screws off or do I have to use a pick to get it off before i put a gear puller on the hub and pull.Thanks Steve
    I don't have any experience with a Hydrotraxx but I would assume if it was a clip, it probably needs to be pulled off with a pick and/or pliers. Do you have any photos of the clip in question? If so, we could probably tell you for sure.
      Thank You Mike i will try with a pick,will try taking a picture with my phone if i have trouble Thanks Steve
