hustler 950 18hp Kohler. .more speed questions
  • hustler 950 18hp Kohler. .more speed questions
    How can I get more top end? I'm only at 10 mph now. What can I do?
    What rpm are you turning. Either you got very low rpm's or a clutch issue. I've never had a 6x6 that would only go 10mph. Something is wrong. Check and see if your clutches are opening completely while in neutral.
      I'll check the clutch. rpms I have no guages. I just had someone follow me. So I new my speed.
        Clutch on motor opens.. bot bigger one on bottom of the belt does not move. I have a red spring if that matters. What can I do next?
          Check the belt for size and tension. It should be wide enough to be flush or slighty higher than the sides of the secondary clutch and only have about 1/2" deflection.
            Was wrong. Both are opening
            It'sflush.. but lose...can move it about 3 inches of play
            Is there away 2 tighten it. I don't see any way to adjust the motor back any.
              I don't believe the stock Hustler allows for the tightening of the belt. You have to either replace the belt or modify your engine mount to allow for belt adjustment:
                What else can I look 4. Belt don't seem 2 b slipping. Check carb? Was supposed to b just rebuilt...
                  I think You need to check the rpm's, somebody may have messed with the governor at some point.
                    The first thing I do is buy a (tiny tach) for every machine, they are a bit pricy compared to generic ones. It is so easy to hook up and they last and are accurate, it's very nice to see RPMs... Norm.
                      Norm, where do you get the tiny tachometer. And how much are they?
                        Do they hold up well in the weather, no fogging up etc
