1970's scrambler
  • waynef570
    replied
    I have a 1968 action age scrambler with the briggs 7hp original running engine in it has brake pedal and gas pedal and steering wheel i picked it up for 375 dollars everything is in good shape and works I replaced 3 lines in it it's all but ready to go but the pads between the discs for drive and steering are shot I was wondering if anyone knew
    how to or where to get these or a homemade fix thatnks
  • curtains21
    replied
    This is not mine but it is the same model. Mine is mint compared to this. I found this on accident while looking for a truck.
  • Nubs
    replied
    photobucket is free and very easy to use, plus if your system crashes you'll always have your photos..
  • allwheeldrive
    replied
    Originally posted by curtains21 View Post
    why is posting pictures on here so complicated?
    Old website, go to: TinyPic - Free Image Hosting, Photo Sharing & Video Hosting hit browse find the picture, than resize (15" works). Then copy the IMG code for Fourms into the the Reply box here.
    [IMG]htttp://i63.tinypic.com/14sdraw.jpg[/IMG]
    Will look like the above but a photo will appear when you submit (I added an extra h in http to keep from becoming a photo)
  • curtains21
    replied
  • curtains21
    replied
    Sorry everyone it has been a crazy couple of weeks with all the snow. It is the 4 seater, with stick steering. I thought maybe the previous owner took out the steering wheel and replaced with sticks. Good to know, thanks for all the information so far. I will try to get those pictures up soon.
    Also, the reverse has a toggle switch I have to flip up then there is a push button that engages the reverse.
  • jpswift1
    replied
    I believe the 4 seater, stick steering models were the later models after the Scrambler Company was purchased by another company (in Michigan I believe). They came with OH160 Tecumseh engines and beefier clutch/friction drive components.
  • allwheeldrive
    replied
    Does this have the electric reverse? Pictures please I have never been able to find any pictures ever of the motor set up! The stick models (no wheel) I believe are the higher end versions, more expensive from what I recall. Is it a 3 seater (1+2) or 4 (2+2)? Wondering if it's actually a later model.
  • 1963 pengor penguin
    replied
    Well the older fiberglass ones are not always as easy to sell and yours has a tecumseh (just a so-so motor) but $2500 would be a great deal with fixed tracks that are fully connected! Its great that you have a few options too! (Windshield etc)
    From the sounds of it u have a nice machine and 2500 is the magic number and anything under 2000 i would NOT take. Goodluck!
  • flippy
    replied
    sounds nice,I have owned 2 scramblers and liked them both,however Mine had no reverse.I have a scrambler now with a max frame and drivtrain,the t20 trans beats the scramblers hydraulic clutch plates however once a scrambler is adjusted properly its a lot of fun.I liked the steering wheel setup.
  • curtains21
    replied
    It also has reverse and that works as well.
  • brian19600
    replied
    Wouldn't reverse be almost a requirement for a tracked vehicle?
  • amphibious drew
    replied
    I think Mike is high. If it is as described, I would say $1500 or so. The tracks add to the value, but not as much as I think Mike figured in his math.
  • Mike
    replied
    Do you have any pictures you can upload to the gallery? I do not know the scrambler market at all but I would guess the value was in the $2,000-3,000 range. Let's see what everybody else thinks.
  • curtains21
    started a topic 1970's scrambler
    1970's scrambler
    I have what I believe to be a 1970 something scrambler. I haven't looked at it close enough to see if it has a sticker on it telling what year it was made. It looks to be all original in amazing shape. It does not have the steering wheel, but it does have skid steer type handles that seem to work very well. Has the Tecumseh 16 hp single cylinder that runs and idles very well. It also has plastic tracks, windshield, LED lights (not original) with the original lights underneath but not hooked up, and front winch. The tracks look to me like standard argo tracks but have no argo printing on them. There are no cracks anywhere on the upper or lower tub and it is fiberglass. I haven't had it in the water yet but there is no indication as to why it wouldn't float. I'm not sure how much something like this is worth. It looks like it has very little use and has always been stored inside, I'm almost afraid to use it. I'll get some pictures up tomorrow. Does anyone have any idea what something like this is worth?
