Got my Wedge project home and signed up for the site. Sticky was good enough to send some transmission advice. After removing the tranny and opening it up, all looks well. No shavings or missing teeth! So basically I am looking for any advice/direction anyone can provide. I need to swap out the old flotation tires for something modern and need to find an engine. All else looks complete. I'm sure I will be rebuilding clutches and replacing cables and so on. I would greatly appreciate anything you can do to point me in the proper direction. It also has a Berkley Jet Pump that looks complete but haven't opened it up. Thanks in advance. Looking forward to consulting with this group.
Sperry Rand Wedge Project Help
Not readily available. Someone told me that some outboard boat engines use the same dog clutch, not sure what model, but they were around 20 HP or less. Mine is locked into forward gear. I drilled through an oil hole on the dog clutch and through the shaft so I could pin it into forward gear.
Sounds like it should be a racer!Originally posted by liflod View PostNot readily available. Someone told me that some outboard boat engines use the same dog clutch, not sure what model, but they were around 20 HP or less. Mine is locked into forward gear. I drilled through an oil hole on the dog clutch and through the shaft so I could pin it into forward gear.l like to buy stuff and no I don't do payments!
