Tri Cart
  • Tri Cart
    Just found another Tri Cart locally. Hopefully have it home in a couple weeks. Looks pretty good except for the axle is broken. Does anyone have dimensions of the axle?
    I've been wanting one to park next to my Wedge
    Parking them takes all the fun out of them.
      They're easier to maintain if they don't move
        i will try to get you some measurements, but I don't know which keyways are stock and what I added at this point. Do you have both halves of yours?
          Didn't get it home yet. He has 2 axle pieces that don't look quite like they fit together.
            Sounds like the perfect start to a build
              I don't currently have any axles w/o wheels attached so accurate overall length measurement might be a tough task right now. Do you need dimensions other than overall length?
              SPD Tricart X5
              SPD Tricart
              SPD Tricub
              SPD Minicub
              SPD Wedge 295
                Diameter would be a good start. Also, do you have a parts diagram drawing of the axle assembly?
                I didn't study this one too much.
                It is complete with good rear tires and the price is right. Picking it up the week after next. I'll have more questions once I get it home.
                  Good rear tires is excellent start. Pretty sure it's 1" shaft... threaded on both ends for fine thread nut. I'll see what I can access this weekend.
                  SPD Tricart X5
                  SPD Tricart
                  SPD Tricub
                  SPD Minicub
                  SPD Wedge 295
                    liflod... this should be pretty close. I measured axle from 2 different Tricarts, one complete with wheels, no body... the other assembled in body without wheels. Overall length probably within 1/8". Kind of tough to get some of these measurements without bare shaft on bench. Check out in gallery.
                    http://www.6x6world.com/gallery/data/706/5400411.jpg
                    SPD Tricart X5
                    SPD Tricart
                    SPD Tricub
                    SPD Minicub
                    SPD Wedge 295
